PCV Valve repair w/o replacing Valve Cover - 2012 Cayenne Base (V6)
Dear Enthusiasts,
Is there a way to fix the Positive Crankcase Ventilation (PCV) valve issues in a 2012 Cayenne V6 WITHOUT having to replace the entire Valve Cover?
Getting the following codes which point to the problem:
P218700 - Bank 1 Fuel Metering System too lean at idle speed
P218900 - Bank 2Fuel Metering System too lean at idle speed
When car is in Park position, it idles rough.
Thanks in advance.
-les grossman
Thanks in advance.
-les grossman
I'm pretty sure that's a VW motor, and it's not used in any other Porsche chassis. Panamera has a Porsche V6. You might want to check with a touareg forum, or some other VW forum as they'll know more about that motor.
