Sponsored By:
Sponsored By:
Cleaning A/C Evaporator
Old Jul 17, 2025 | 04:45 AM
SMOO2020's Avatar
SMOO2020
Unhappy Cleaning A/C Evaporator
Hi everyone,
I have a 2016 Porsche Cayenne GTS and I’m facing two issues with the A/C:
  1. Sometimes I get bad smells from the A/C.
  2. During the daytime, the A/C takes a long time to cool the cabin properly.
I already changed the cabin filter, and it helped a little, but not much.
I believe the problem might be with a dirty A/C evaporator (cooling coil).
Can anyone please guide me on how to clean the evaporator using popular A/C cleaning sprays or foam products (like Würth, Liqui Moly, etc.)?
  • Where should I spray it?
  • Do I need to remove anything?
  • Is there an access point from the cabin or under the hood?
Any help or tips would be really appreciated. Thanks in advance!
Old Jul 17, 2025 | 05:00 AM
EchoGTS's Avatar
EchoGTS
Watching this thread 👀
same exact vehicle similar issues developed recently .
Old Jul 17, 2025 | 07:28 AM
mdistel's Avatar
mdistel
I would start by confirming the AC drain is clear. Its the little hose exiting above the passenger footwell that attaches to the base of the evaporator box, it can be pulled off and to reinstall spray with silicon or some lubricant as it's a tight fit. If it's clogged that could lead to the excess moisture and smell. if it's freezing up then you could have low refrigerant, this usually means cold AC when the car is started turn reduced output as you drive. I've never cleaned the evaporator on a car but if similar to a home you would spray the foaming cleaner through the air filter access. Even my 2009 doesn't smell and I'm in FL so confirm the drain is working.
Old Jul 17, 2025 | 08:09 PM
garrett376's Avatar
garrett376
Just take out the cabin air filter and you can spray whatever it is you have onto the evaporator from there: you will be able to look right at it when you remove the filter.
Old Jul 18, 2025 | 08:02 PM
dlr944's Avatar
dlr944
I use the Toyota ac kit to refresh the ac system. Works great.
Old Jul 19, 2025 | 09:18 AM
sasilverbullet's Avatar
sasilverbullet
Veteran: Air Force
What you need to do is clean the condenser that's in the front of the radiator. If the fins are clogged then the cooling will diminish.
If that doesn't fix it take it to a reputable A/C shop and have them check the system. You might have a leak and are low on freon.
Old Jul 19, 2025 | 09:48 AM
CarreraCup03's Avatar
CarreraCup03
as suggested get the root cause fixed. Either by you or a professional. then use frigi fresh. works really well on musty smell etc.
