2016 S 90K Tune Up While he’s in there…
Slight oil smell when hot sitting still. Coils will be done,plugs already done. Valve cover gaskets? Water pump? What else while he’s in there? Plan to keep it a while.
New kitchen so no new Cayenne
I have a 2013 Turbo and when I did the coils and plugs I also did the water pump, serp belt, pulleys, and thermostat. I did the work myself. When I pulled out the water pump and examined it, the bearings were definitely on their way out. I don’t know what they will charge you because they will have to get a bit deeper into the engine to get the therm and water pump. If you’re keeping it, I would do the water pump and therm. Peace of mind.
