Reset Check Engine P2189 P2187 with Durametric?
Hey Guys
I got the classic P2189 and P2187 codes and confirmed the pcv valve was at fault and replaced it. I am trying to reset the check engine light with my Durametric by clearing the faults, but it doesnt work. It says it did it, but nothing happens. Does this check engine light go out on its own after a few drives? Or is the durametric supposed to reset this?
Thanks,
John
Thanks,
John
aryork (08-10-2024)
Can you reset the oil change light with the Ancel AD410? When I ask the question, " can it reset oil light on 2013 cayenne" one of the suggested models of scanners on Amazon says, '2013 cayenne oil reset, can't be done manually but will reset itself after an oil change and driven some' I've never heard or seen anything like that - anyone else know if it resets automatically after oil change? I've always seen the tech reset it with some type scanner.
not sure if you can. I use the diametric for that without a problem.
I can take a look and see if it’s possible. Definitely not going to reset on its own.
