Hi all had my Cayenne for about two months and now after a road trip the oil has started overheating under load. I am thinking about doing a full oil flush since the car is a bit older. I made sure the flaps in the front are open to avoid that rookie mistake. Any advise is appriciated, engen sounds healthy no weird noises.
So, I just finished the oil flush with seafoam and new oil in, using Mobile 1 5w-30 . Sadly, the issue still persists. The next step is possibly replacing the water pump with a new thermostat, I have heard they can partially fail. Causing the coolant not moving fast enough through the block at higher RPM.
