Looking to twin turbo my CD3.0
3rd Gear
Like I said, looking to TwinTurbo, my Cayenne diesel. Looking for advice on whether to do staged or banked turbos and what kind of turbos to use and all that currently has RawTech stage two with full delete. Also looking for advice on a slight lift of an inch and a half to 2 inches
The 2 big suppliers for lift kits that I know of are:
For the power adding. I'd try reaching out to Darkside Developments in the UK. They've done quite a bit of work to these motors and might be able to help you out. I know they've done turbo upgrades before, not sure if they've done any twin turbo builds yet though.
- Eurowise Lift Kits
- They have 2" and 3" kits for stock steel, stock air, and aftermarket coilover suspensions along with a good selection of additional upgrades such as tubular upper arms (for camber adjustment on larger lifts) HD links and bushings, etc.
- Emotion Engineering Lift Kit
- They just have the one kit that I know of which is a 1.5" front, 1" rear spacer kit
Offroad_958.2TDI (07-01-2024)
