Recalibrating regenerative braking
Hello!
Please, help me out. I have the 2016 S E-Hybrid and over the weekend I lifted the car to check some noise coming from under the car. I accelerated the car while lifted and surely, it began to flash all sorts of messages. After driving a little all errors disappeared but one problem still remains: the regenerative braking seems not to work anymore and also the gauge doesn't go indicate the charging status; the indicator goes up into "efficiency" but not down into "charge". Cruising charges the battery just as normal but the brakes seem not to.
I saw other forums like the Tesla's that people seem to have the same problems after changing wheels or similar operations involving lifting the car. The brakes seem to reset themselves and then they need to re-calibrate in after some driving; but I drove around 350 km (some 200 miles) and nothing. Even more, there seem to be an error, which I discovered with my OBD, as attached in the images below. Erased them once - appeared again.
Thanks a lot, any help is greatly appreciated!
