My first SUV, first Diesel, with Air Suspension
Just purchase a 2014 Cayenne Diesel with Air Suspension, with 230K miles on the clock. Took me half a year too find a CD with air suspension at a great price. I'm pretty excited to work on this car and drive around since it's my first diesel car, and first SUV that's I'll be using as my daily driver when the 992 get's tiring. The air suspension makes the ride just as comfortable as my e38 740iL. Maybe I'll sell the e38, idk. It has tow package, but I don't tow anything.
There's a laundry list of maintenance that I compiled that I'd like to do to get a peace of mind. Let me know if I'm doing too much or if I'm missing anything.
Mods
- Brake Pads & Rotors (urgent)
- Brake Fluid - 207K 1/2023
- Engine Oil & Filter
- Engine Air Filter
- Fuel Filter
- Cabin Air Filter
- Wheel Alignment
- Drive Belt (looks okay)
- Front Differential Oil - 186K
- Rear Differential Oil - 186K
- Transfer Case Oil - 186K
- Transmission Oil and Filter - 186K
Mods
- Mr12Volt Carplay
- Clear side markers
Al Faromeo (06-13-2024)
I'd check all your suspension bushings. At 230k miles, they're probably getting pretty tired if they haven't been replaced yet. I'm prepping to do mine this summer at 140k.
I'd also recommend installing the trailer connector in the rear if it hasn't been done yet (they have a block off plate from the factory). You may not think you need to tow anything, but it's nice to have the option to if the need arises. Plus, these things tow amazing, especially with the load leveling capability of the air suspension.
Congrats on the gorgeous color scheme and on finding the extremely rare air suspension on a Diesel. Counts as a unicorn in my book.
NightFury: I see what appears to be a block off plate from the factory on mine. I presume there is no tow hardware behind, so the options seem to be a Curt or Draw-Tite aftermarket one, unless people here advise getting a factory one, which I suppose will come at an unreasonable cost, unless it comes with great advantages? Anyway, at this point, my main concern is about electronic or electric hardware required to wire the trailer. Just tap into the backlights? Or is there an electronic box to be sourced from the dealership?
blackairforce1 (06-12-2024)
Yeah, it was half an hour away from me.
Suspension bushing looks okay, but I'll take a closer look when I'm doing the brake job. I hate replacing suspension bushings. It should already have the trailer connector but I'll check.
Also this car is equipped with Power Steering Plus. What does that do on this car? Makes the steering lighter? Can it be coded off?
Just found out the entire drivetrain fluid was replaced at 186K. Is it still due at 230k miles, or am I good for another 24K miles on the ATF?
if your Cayenne didn’t come with factory tow, then you’ll need a trailer module for controlling lights etc. and an additional wiring harness. Tow package is also pre-wired for a trailer brake controller, just need a breakout harness for under the dash and your preferred controller.
World Player (06-12-2024)
Congratulations on the car, it looks to have taken the miles very well. I love the espresso and cognac interior, I have the same in my car.
I have just been living with mine, I think mine is just the timing cover leaking and I think that it's not as bad as I thought - when I changed the oil a few weeks ago I fitted a new drain plug, obviously with a new crush washer, because the old drain plug looked tired and never looked clean. I have a piece of cardboard in the garage where I park my Cayenne which normally has oil drips on it straight away but so far it is clean.
What does bother me was that I found coolant leak in the valley. Looks like I'm going to tear down the intake manifold and replace oil cooler gaskets, and clean out the soot in the intake. Also, the speakers (except the subwoofer) stopped working for a moment until I restarted the car. I think the BOSE amp is on it's way out. I'm a masochist for clapped out euro cars.
CP4 Bypass Kit?
Is it a good idea to install a HPFP metering valve bypass kit while I'm under the intake manifold to address the coolant leak?
https://whitbreadperformance.com/pro...44741025890463
I've been reading about the risk of HPFP failures destroying the fuel injectors which is $$$$. Does anyone have any experience with failing HPFP, or installing this kit? Or will changing fuel filters regularly mitigate HPFP failures? Keep in mind my HPFP has 230k miles on it.
