Mystery water intrusion 2013 GTS
#31
I think I will try this next. I rained pretty heavily earlier today. The well at the bottom of the kick panel was full and dripping from the small push pin hole that holds the felt insulation. That water runs down into the footwell and will eventually flood the footwell as we all know. Oddly, I do not have any wetness above this area. Nothing visible on the upper A-pillar, airbag dry. Nothing in the headliner. I wasn't able to get a good look at the inside of the wire bundle door jamb pass-thru with my endoscope in the few minutes I had to fool with it here at work. I want to try that while it is still wet.
I am still thinking this is coming from the windscreen into the inside of the a-pillar and running down to the floor.
I will tape off the sunroof to isolate that source, then pop off the rain gutters on the windscreen and soak the car for a good long while.
Worst case scenario, I will drill a damn hole in the bottom of the body cavity that is filling with water.
this was the status on my CD.
You can clearly see the waterline on the insulation.
#32
What are we looking at in your first photo? Is that some kind of body repair with body filler?
#33
It shows the body seam sealant after I scraped a bit with a small flat head. What I'm trying to say is that 50% of the seam sealant in that position was loose and fell of when tempering with it. I had a lot of water intrusion and filled the void fast. After removing as much sealant as possible, cleaning and putting new sealant on, there is no more intrusion.
#34
Sorry for a bad explanation. First picture is from the corner under the windscreen, picture is taken from inside the fender.
#35
#36
So for a variety of reasons, I had not been able to get to the area you described. However, I found out that fresh water intrusion is covered under comprehensive insurance.
The vehicle is now at a Porsche certified collision repair facility. They have put the vehicle through a water test and confirmed the leakage. They are hunting down the source of the intrusion and are targeting the very area you have indicated. Would you be able to indicate on my photo where the area you repaired is?
Thanks.
#37
Update:
Thanks.
Thanks.
Marked the seam seal in blue. Dotted red line represent the leaking seam.
BR
Hector
The following 2 users liked this post by hector024s:
coletrain (07-31-2024),
skidpalace (07-22-2024)
#38
Well, if you are reading this looking to DIY a water leak in your Cayenne, DO NOT bring it to a Certified Porsche Collision Repair Center. You will probably not get your car back. I brought mine in to have them look at it and they told me, "Oh no this is minor. It won't be totaled". Fast forward a couple of weeks to where it looks like the above picture and guess what? Extensive rust and corrosion behind the dash and the sum total of visible repairs as well as the liability for missing safety system issues deems this a total loss by the insurance company. WTF. Sure there was a little light surface rust but nothing to worry about.
My car is gone. My Boxster a few weeks ago and now my Cayenne today. Although I was OK with losing the Boxster as it was long in the tooth, This Cayenne was pristine with only 58K on the clock. I am not happy at all.
If you are combing the Copart lots looking for a good Cayenne GTS, keep your eyes peeled for this one at the South Boston Copart in a couple of weeks. All maintenance done by Porsche dealers, new transfer case in January 2024. Other than the leak diagnosed here, the truck is perfect.
#40
Instead, consider letting them know what your number is, why and ask them for arbitration right up front.
#42
I am sure that by now you have a number in mind. If their offer is not enough, they may start the game of " bring a list of cars that meet certain conditions, blah blah blah". Then they look at what you bring back and offer you their original offer, and the do loop continues.
The following 2 users liked this post by skidpalace:
CAVU (07-26-2024),
hector024s (07-31-2024)
#43
Did they at least manage to find the source of the leakage?
I hope you find good replacements for both vehicles when the time comes.
#44
I am contemplating buying the Cayenne back from the Ins company. I am waiting on figures.
#45
Afraid not. They got the info from this thread but hit a full stop when they opened it up to reveal a corroded airbag module and the surface rust. The repair bill to the ins company was over $23K.
Just some food for thought from the cheap seats:
- The repair bill of $23k is just the starting figure. IMHO, there is more damage yet to be discovered.
- I enjoy a challenge. I do not like water damage challenges. Been there done that too many times.
- I suspect they will go through the motions to "mark" the title to something not desired no matter the direction it goes.
Hang in there.
