Tires size for 21x9.5 front and 21x11 rear on 958.2
Hi,
I have a set of 21" OEM RS Spyder from 9Y0 Cayenne GTS, and wondering what tires size should I put for our 958.2.
- 21 x 9.5 front
-21 x 11 rear
I think for the front I will leave it 295/35/21 but what size should I put on the rear wheels ?
Thanks for your advice !
- 21 x 9.5 front
-21 x 11 rear
Fronts: 285/45/21
Rear: 315/40/21
Don't know if that's gonna work on a 958.2 in regards to gearing and transmission shift points. I wouldn't do it.
Do 275 45 21 front and 315 40 21 rear. Will fit perfectly no rubbing. Nice cushion
I just found for 9Y0 OEM tires size has 2 possibility:
- Front 275/40/21 ; Rear 305/35/21
and
- Front 285/40/21 ; Rear 315/35/21
Which one you think will be "better" for 2011-2018 (958, 958.2) ?
Can I keep the front 295/35/21 and rear 315/35/21 ?
and
