does anyone have advice or a guide to wiring, components needed, to install new amps, subwoofer and speakers? please dont tell me to search and then send links to tweeter upgrades, PCM upgrades and posts asking for opinons on which equipment is best. If anyone has first hand experience with installing a new systew( powered by new amp) or subs, I would appreciate your help
99 views and no replies, well until this one. Keep your topic in one thread and it will be easier for your topic to get some traction. No need to start a part 2. I'll try to provide some input on the original thread.
Ha, ok I'm back. LML shut down your other thread I should have accepted the Team Member position except I would have fully abused it and banned all you guys. 😂🤣😂
Here ya go. I just did a simple search on Google and this popped up.
well that’s pretty sad, I appreciate it, normally I don’t trust these diagrams unless I have a way to know them to be true, but if you have experience and your saying it’s correct then I’m good with it
Don't look a gift horse in the mouth. I have absolutely no experience with the Cayenne's PCM system. Like I stated, it was a Google search. If you want traction in your thread, you have to be detailed. Cayenne model, and stereo it's equipped with.
If you don't trust the wiring diagram to be true, then verify it on your own. Pull out the system, take a 9V and test the speaker leads, then test the power, trigger and ground. If those check out then it's a pretty safe bet that the diagram is correct.
