2016 CD - oil-gunck on engine
Hello
I have a 2016 Cayenne with 3.0 v6 diesel.
The engine has a layer of oil-gunck on both heads and the block. The pulleys and everything else looks quite OK.
I have not done much investigation, so I have no idea where its coming from.
what strikes me as a bit odd is the everywhere-part. On top of the heads, on the front of the block.. having a hard time wrapping my head around that.
Anyone else experienced this?
Anyone got any idea where to look for a source?
I've had really good luck with a mild degreaser like Simple Green. Do a mild dilution of 2 water parts water 1 part Simple Green, let it sit for 5-10 minutes then LIGHTLY pressure wash off with a 40 degree washer nozzle.
Ill give it a go when temperatures rise above freezing on a permanent basis.
If anyone got any suggestions on where to specifically look for oil-leak, its greatly appreciated.
Is the car still under warranty? Take it to the dealer if it is.
By the way I clean my entire engine compartment with 2:1 simple green and a medium spray from my garden hose. Works great.
I also was able to slow/stop my oil leaks with LiquiMoly oil saver.
Good luck
Eric
Good luck
Eric
Let the solvents in the simple green do their thing for a few first. Ten or twenty is plenty. If you’re afraid of wetting something important hose off the engine with it running. You’ll know if you’ve done something bad right away.
Good luck
Good luck
