Any hope for my key fob?
Wife washed my pants with key fob. I let it dry out then put a new battery in it. When I went to use it, it does not open the 2015 Cayenne S. I do get a red dot appearing/falshing on top of the fob. Is it possible it just needs to be reprogrammmed? Or is it toast?
VicS (01-19-2024)
Mu suggestion:
- remove the battery asap, do not try a new one.
- take it apart as much as you can
- fully dry it out
- clean the circuit board using a q-tip dipped in iso-propanol to remove any salt traces. If you cant get the PCB out ( i havent tried) then maybe you can wash it in iso-propanol, although that may damage the decal.
- reassemble and insert new battery - good as new
