Sponsored By:
Sponsored By:
New to Porsche and have a few questions
Old 12-01-2023, 01:47 PM
patc890
patc890's Avatar
Thanks. This one was much warmer than that. I'll check it out again.
Old 12-01-2023, 01:48 PM
garrett376
garrett376's Avatar
Originally Posted by wyowolf
Not even fully warmed up and it came up
What was your oil temp? Over 149ºF?
patc890
patc890's Avatar
I'll try that.
Old 12-01-2023, 01:50 PM
patc890
patc890's Avatar
I'm not sure about the oil temp. I think it was pretty low though. I remember thinking it was was way lower than the coolant which was 200F
Old 12-01-2023, 06:25 PM
mikescayenne
mikescayenne's Avatar
the dealer showed me a trick that works everytime on all porsche models that measure the oil level with the computer. Turn the car on and warm up the engine to operating temp, doesnt matter if you drive it or let it idle until it reaches operating temp. Then make sure the car is on a level surface. Once the car reaches operating temp, turn the car off and then turn the key back to the on position without the engine running, after 60 seconds the oil level will show up!! it works every time !!! And like previously stated above, always remember that opening the hood resets that reading.
edit: ​​​​​​@garrett376 is a treasure and has already mentioned this above! my apologies! i always thought it was 60 seconds with the ignition on and engine off but it looks like its 120 seconds actually!
The following 2 users liked this post by mikescayenne:
Dr. G7 (12-02-2023), Hawkpilot6060 (12-02-2023)
Old 12-01-2023, 07:03 PM
patc890
patc890's Avatar
Thanks I'll try that.
Old 12-02-2023, 01:03 PM
CDMC
CDMC's Avatar
Just a general suggestion. You may want to find a good independent service shop in your area and have them do a pre-purchase inspection. This will 1) help you get a baseline on the vehicle, 2) budget for any things that may need to be repaired in the near future, and 3) see if you like the shop and are comfortable with it before you have an emergency repair.
Old 12-02-2023, 09:10 PM
Dr. G7
Dr. G7's Avatar
Originally Posted by patc890
...My daughter got 2014 Cayenne...as part of her divorce settlement. When her ex had it dropped it off on a flatbed at her house all he told her was not to drive it until she takes it to the dealer. He’s the type that might do something to it.
You should absolutely take his word for it. Personally, I would not have even cranked/started the Cayenne. I would have immediately placed the Cayenne on a flatbed, take it to a known indy. Get all the fluids flushed/changed and filters changed. The ex might have inadvertently dropped some sawdust or banana peels in the oil!
A blown engine in this
Cayenne = Vehicle with a net value of zero dollars. Maybe even negative equity to have it junked.
Old 12-02-2023, 09:14 PM
Dr. G7
Dr. G7's Avatar
Originally Posted by CDMC
...them do a pre-purchase inspection.
It is a transfer of equity in a divorce settlement.
"You may want to find a good independent service shop in your area and have..."
Spot on. Absolutely correct.
Old 12-02-2023, 09:18 PM
Dr. G7
Dr. G7's Avatar
Originally Posted by garrett376
...pretty neat to be able to check your oil level while cruising along.
You do this often? I prefer other distractions.
Old 12-02-2023, 09:20 PM
Dr. G7
Dr. G7's Avatar
This is the actual info from Porsche about the oil level readings ....
All this because Porsche was able to save 49cts by omitting the dipstick.
Old 12-18-2023, 02:20 PM
patc890
patc890's Avatar
So my daughter brought it into the dealer. They came back with a quote for over 15K! They did say there was a fluid leak but everything else was maintenance type work.
LEAK IS UNDER THE INTAKE MANIFOLD, SUSPECT THERMOSTAT HOUSING , Y PIPE - $4475
Boy I'm glad I don't have a Porsche
Old 12-18-2023, 03:47 PM
jpru2001
jpru2001's Avatar
$10,000 in maintenance work? lol.
Take it to an independent mechanic that specializes in germans and you are probably looking at a couple thousand.
Old 12-18-2023, 04:02 PM
patc890
patc890's Avatar
Yes I figured that would be the case. A few of the estimates they gave. Are these normal?INTERIOR WATER ENGRESS
Correction
R AND I CARPETS CLEAN, CLEAN DRAINS
$ 5,748.24
FRONT BRAKE PADS WORN (YELLOW)
Correction
MONITOR PADS FOR WEAR AND REPLACE SOON
$ 2,210.93
REAR BRAKE PADS WORN (YELLOW)
Correction
$ 1,688.18
Old 12-18-2023, 07:41 PM
Dr. G7
Dr. G7's Avatar
As mentioned elsewhere find a good reputable indy.
I just did my 60k service. Same checklist (Major Service that includes plugs, brake fluid flush, filters, fluids, drain cleaning, etc.) as Porsche. $850. At a Porsche dealer $2500- $4200
Quick Reply: New to Porsche and have a few questions
