I have been trying to calibrate my air suspension on my 2011 CTT. Initially I tried with the Launch X431 which allows me to do the component test (car goes up and down) but fails at the calibration step. Thinking it might be because of the X431 I bought myself a PIWIS 3 but that gives me a "component test unsuccessful" due to 62079 height sensor component test could not be performed - negative response from control unit,.
I thought it might be due to low voltage so I hooked up a 50 amp battery charger, but even with 14volts I get the same message. I can see the hardware, software and input values of hight sensors etc.
Not faults in PASM memory
Hi I saw this same on a scan I did today. So did you have any other DTC's ? I also had a error about CAN communication error and Drive Battery voltage -Deactivation stage active. I will try again tomorrow. I just replaced my left ft air shock. and Battery was out for 2 days. Good luck!!
Did a full scan today again and got the following code in the PDCC module: “C1208A check PASM fault memory content” but that’s the only one.
When I check PASM/Level control there are no faults. System works normally only my ride is very hard.
Car level is adjustable PASM module Test failed at 14.1 volts No faults in PASM memory Fault in PDCC
