Windshield Washer Pump Fuse Location
Trying to identify the correct fuse location for a 2016 Base Cayenne windshield washer pump. The owners manual has very detailed fuse box identifiers, but I cannot find any entry for windshield washer pump. My 2010 had the fuse on the left side dash fuse box. I've searched these forums, Google, AI and can't believe nothing lists the w/w fuse location and number. Winter is coming!
Turned out to be the pump. It was obvious when I pulled the fender wheel liner and looked at the bottom of the pump. Replacing the pump is a fairly easy job. Jack passenger front corner, remove wheel, remove a lot of screws and pull the liner from the wheel well. Handle the liner with care - it's about $350 if you damage and have to replace!
The pump has a front connection and a rear (washer) connection on the back side that's difficult to see, and it drops into washer tank grommet and is held in place with friction. To pull the lines, there are little clips at the end of the lines that must be released (don't try to just pull them off without releasing the clip). It's easier to disconnect and reconnect the lines when the pump is pulled off the washer tank. Just make sure not to pinch any lines when reinstalling the pump to washer tank grommet.
Take you time reinstalling the screws - note that a few underneath are a little different/longer - and leave them all loose until the liner is in proper position and hooked into fender, then tighten all of them. Good Luck!
