Adding Tow Capabilities - Parts needed?
Hi all,
I recently picked up a new (to me) 2012 Cayenne, it has almost everything that I want, with the exception of towing.
Having read through the various threads on towing, thanks to those who have contributed, I believe that I need the following (but couldn't find confirmation):
Thanks!
- Cayenne Trailer/Towing Control Module 7P0907383
- If I buy used, it should be preprogrammed, and if working, no coding required
- Porsche Trailer Tow Harness, Part Number: 95861250600 (this adds 7 Pin)
- A 2" hitch, I was thinking of going Curt, or something from eTrailer (I installed one on my old Cayenne, and it was simple, but I never did wiring)
Thanks!
Look for a similar year Q7 tow hitch. You should be able to pick one up for not much more than an aftermarket hitch. I think I paid $300 for mine.
You'll need new (longer) mounting bolts.
Otherwise, I think you're good. Make sure the harness has the seven pin connector.
Thanks, I'll take a look for a Q7 hitch and see what I can find. Then it's all OEM ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
@lml999 It's good to see that you are still here, the forum seems a little quieter than when I was last here, which was during Covid, and we are all locked down and WFH!
The Q7 hitch is exactly the same as that coming in a Porsche box. I found mine on ebay. Just make sure that you confirm that it's OEM versus aftermarket before they ship...and confirm that it's from a 2011-2015 Q7. They should *look* absolutely identical (because they are!)
I asked one seller to confirm that what they were selling was OEM, and I guess they decided it wasn't worth the effort to actually remove the hitch from the parts car...and ended the auction. Hmmm.
