2014 CD Window Problem
One of the back seat windows on my 2014 CD is going back down after it is fully raised. I have have to play around with the up/down switch quite a bit to get it to stop at the fully closed position. I suspect it needs some relearning. There doesn't seem to be any binding, it moves up and down at the normal clip. I've tried the generic lower it down, hold the switch, raise it up, hold the switch routine, but it didn't change anything. Any suggestions?
