Rear driver window..stuck? (Solved)
As title says.
the rear window is stuck (up thankfully)
It won't go down, just hear a click in the door.
The odd thing is.
The sunshade won't go UP either.
That also just clicks.
This happened out of nowhere, I can't even recall the last use of that window, its been about a month (ac on all times in Fla heat!)
Anyone have a clue why BOTH functions are not working all of a sudden?
The odd thing is.
Issue SOLVED
Lifted up the flap containing the sun shade and lifted the shade manually. This allowed the cycle to complete and now everything travels as ut should.
I still wonder why/how it got stuck in the first place.
Glad you got it figured out. Thanks for the update.
