Sponsored By:
Sponsored By:
How to turn DRL off when in Park
Old 05-04-2023, 09:51 AM
cayennepeppa
cayennepeppa's Avatar
Default How to turn DRL off when in Park
Going to a Drive in Theater this weekend, and they mentioned that all lights must be off when in Park. Can anyone please help me on how I can turn all the lights off when parked in ACC mode, as I still need to keep the radio running. Mine's a 2016 Cayenne Base.
Old 05-04-2023, 09:58 AM
cayennepeppa
I did look at the Vehicle>setting>lights and Visibility - It only gives me the option of fading out timing but doesnt let me turn them off completely.
Old 05-04-2023, 10:09 AM
lml999
lml999's Avatar
@cayennepeppa Maybe pull the two fuses for the headlights. I don't see fuses for running lights listed separately.
Old 05-04-2023, 10:24 AM
cayennepeppa
Thank You ! Apologies for the stupid question (as Ive not done this before), can I just pull out the fuse and put them back in after the movie with no issues? or will it throw some codes that I need to clear? I am going to try it out now but just wanted to make sure.
Old 05-04-2023, 11:11 AM
Needsdecaf
Needsdecaf's Avatar
Received 2,615 Likes on 1,623 Posts
I think...do the DRL's come on when you first put the car on, but not start it? I'd have to try this, but what happens if you get out, lock the car, unlock, get in and turn key to accessory? Do the DRL's come on?
Old 05-04-2023, 11:13 AM
cayennepeppa
Just tried pulling out the fuses for headlights, and that turns off the headlights but the DRL's still stay on. Not sure which fuse these are connected to. Any input appreciated.
lml999 (05-07-2023)
Old 05-04-2023, 11:39 AM
cayennepeppa
Yes they do. Even without turning car on, just putting it in Acc turns the DRL's on.
Needsdecaf (05-08-2023)
Old 05-04-2023, 11:56 AM
lml999
lml999's Avatar
@cayennepeppa Weird...I don't see any fuses listed for the DRLs. Evidently dealers won't even code out the DRL. Looks like Porsche considers this a mandatory safety option in the US.
For the earlier Cayenne, the 958.1, they can be turned off:
Vehicle Information screen > Settings > Light & Visibility > Exterior lights > Daytime light
Old 05-05-2023, 07:24 AM
Windjammer
Windjammer's Avatar
I thought DRLs turned off when the parking brake is set. Might want to try that.
Old 05-05-2023, 07:55 AM
jaustin
jaustin's Avatar
^ that would make sense. Seems like they have to have a built in way to turn they off.
Old 05-06-2023, 11:56 AM
yetti96
yetti96's Avatar
I tried this when I slept in my car with it running once. Lights remained on. I felt bad but was annoyed and ready to sleep, my tent had 4" of water in it so that was no longer an option.
Old 05-07-2023, 08:55 PM
reneeweiss
reneeweiss's Avatar
Not a good idea to sleep in a running car unless you have windows open and well vented CO will kill you.
Old 05-07-2023, 11:11 PM
yetti96
yetti96's Avatar
Not trying to derail the thread, but you’re saying it’s safer to open windows and allow the exhaust possibly enter the vehicle? (I googled and I guess you’re right, not a good idea).
My response was to quote a movie “but did you die?!?”
Old 05-08-2023, 12:10 AM
reneeweiss
reneeweiss's Avatar
This past winter a couple were found dead in a house that had a generator running outside near the window which was closed and the generator had run out of gas. Carbon monoxide can sneak in very easily. Probably best to not sleep in a car with the motor running with or without windows open. I just got a portable generator since losing power and having my office flood because sump pumps need electricity and I bought two CO monitors for my bedroom and living room in case I have to use the generator which is about 20 feet from the house and probably now that I have it will never have to use it! In hindsight perhaps I would have been better with a bilge pump and battery. We lost electric for 18 hours and had 3 inches of rain. Now in Ca. sometimes PG&E turns off the power to reduce wild fire danger. The generator is small and portable but will run the fridge. In general it seems there are so many things that we either can't control or are difficult to control on our Cayennes.
yetti96 (05-08-2023)
Old 05-08-2023, 12:18 PM
lml999
lml999's Avatar
I think we are a bit off topic here...
Quick Reply: How to turn DRL off when in Park
