Camshaft Deviation
Camshaft Deviation
Hi, Im writting from Lima - Peru
This is my first Thread
I have a 92A 2011 Cayenne 4.8 Turbo
Yesterday a read the Camshaft Values with the Autel MaxiSys Ms906BT and this is what it Showed, i'm not sure if the are in spec or if they are not, if so, what would could the problem ?, worn Tensioner, guide or streched chain?
Thank You.
and sorry for mi english.
Thank You.
Hello Pepe,
I would say a stretched chain. The deviation is on both banks. How many miles does the car have?
Any known history on an eventual renewal of the chain?
The deviation should be between minus and plus 6 degrees. At ten degrees the MIL will light up.
By the way I don't think your English is bad
Greetz A.J.
Greetz A.J.
