servotronic power steering OR power steertin +
7th Gear
I need to replace my leaking steering rack @ 110k miles - but there are two models w/Servotronic or w/o Servotronic. [ Due to budget, unit will be a used or remanufactured. I just had the timing cover repaired for $$$$$. ]
Local dealer says I have Power Steering Plus. Is that the same as Servotronic? How do I know if I have Servotronic?
Thanks in advance.
Thanks in advance.
Probably need to specify a model year and which model Cayenne in order to get a decent answer.
7th Gear
Car is a 2013 cayenne GTSCar is a 2013 cayenne GTS
Car is a 2013 gts. Is power steering plus the same as Servomatic?
QUOTECar Car is a 2013 cayenne GTSis a 2013 cayenne GTS=smrfld;18622113]I need to replace my leaking steering rack @ 110k miles - but there are two models w/Servotronic or w/o Servotronic. [ Due to budget, unit will be a used or remanufactured. I just had the timing cover repaired for $$$$$. ]
Thanks in advance.[/QUOTE]
