P0016
Hi,
This morning I started my car and got the message PSM deactivated and Start/Stop not available. The car runs completely fine and smooth. The Check engine light is not lit. When I read the fault-codes the DME gives me the message "P0016 Crankshaft Position Camshaft Position; Correlation (Bank 1 Sensor A)". when I delete the fault code and restart the car everything is fine.
The car had all the Service campaign done (also the Cam-adjuster bolts). The car has a little less than 240000 km (around 160000 miles) and was serviced by the previous owner Porsche.
The car is a 2010/2011 Cayenne S with the 4.8 V8
Maybe someone can help. Thank You in advance
Hi,
