new to the forum. not sure what the symbol highlighted in photo means but it has something to do with coolant. The temperature for this symbol has a huge variance now since i have topped up the coolant. with in 5 minutes of driving off, temperature for this symbol climbs up to 100 degree celcius and sometime even more. previously the temperature only hit this high when the car was in off-road mode and in the desert sand. I live in Riyadh, Saudi Arabia. Any help would be appreciated.
The highlighted symbol is your oil temp. The one above it is your coolant temp. The one below is your oil pressure. Top symbol is your boost pressure. You can change which items are visible on your display.
As long as your numbers are in or near the middle of the gauge , you are good to go. At least in US cars the coolant will get to 200F and stay there. If you are in to coding , I think you can actually get a minute by minute number. The oil temp and pressure will vary as you drive . The highest I;ve seen my CS is 240F oil temp. Usually hovers around 210 to 220. I dont display my boost so cant help you there, I have battery voltage as my 4th item to display.
