Multiple failure including Transmission & ABS
Hello everyone. I’ve had incident free motoring for a while until today when whilst driving a slew of error messages came up causing major loss of power and erratic braking. Any ideas appreciated but I will try to take it to a local indy ASAP. One question I have is whether it is likely to cause damage by attempting to drive it further.
Car:
Here is the fault data from a generic fault code reader. These seem to be the relevant items, full data file is attached. I haven't checked any fuses. Would be interesting if anyone has the wiring diagram to see if there is a common point of failure for transfer box & ABS.
Thank you!
Car:
- 2011 CTT 4.8
- Full service done just less than a year ago
- Transfer case was replaced 1y ago with the new type.
- After driving for about 1 hour, it suffered loss of power when pulling away from lights, PSM warning light came on.
- Shortly afterwards, multiple errors came up including PSM, PASM, 4 WD “overloaded”, ABS, Chassis Ride Height, parking brake.
- The ABS would also come into effect sometimes when braking gently.
- Power transfer was erratic, sometimes it would barely move at all. Engine revs were smooth and gearbox was not shifting erratically, seems like the problem is the transfer box.
- I tried turning ignition off / on
- After a while it stopped being erratic, ABS and PSM lights remain on.
- Ride height is normal and electric parking brake is still operating correctly.
- Battery may be original but voltage level was showing 14.4v with ignition on, I had done a 1hr journey 2 h before the fault and trickle charged it 1 week ago.
============1==============
U0414 Raw code: C414
ECU: Engine control unit
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
OBDII: Invalid data received - four wheel drive clutch control module
============2==============
12831 Raw code: 00321F
ECU:
02. Transmission control unit
Status: Test failed, Confirmed
============3==============
72456 Raw code: 011B08
ECU:
03. ABS control unit[Archive (inactive)]
Status: Confirmed, Test not completed during this operation cycle
Status bits: 1
Priority: 1
Frequency: 1
Unlearning index: 48
Odometer: 127269 km
Date, time: 2022.07.01 17:27:05
ECU:
ECU:
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 127269 km
dollarlongnecks (07-02-2022)
Thanks, yes, it is "potentially". I've owned it 1 year, no record of it being replaced. The CTEK charger doesn't indicate a problem with it. I know its not great if it is original, but as these errors came up well into a drive rather than at startup I thought it would not be the cause of this.
Anyway, I guess I'll charge it with the CTEK and drive it to the indy garage.
Ah, this thread from describes very similar symptoms to what I just got. The problem reported was 2 ABS sensors (BTW, that seems pretty crap to me that the ABS module doesn't detect the sensors to be faulty rather than randomly shutdown other critical functions on the car!). The day before this happened, I drove at 50-70MPH on roads with a fair bit of surface water, can remember the sound of it hitting the undercarriage. Maybe that didn't help.
I realise the battery could be the cause and is sensible to check, but I happen to have the system voltage always displayed on the instrument panel and I could see it didn't fluctuate during this time, staying above 14v.
@diamond-back , @Goody were you able to drive safely at low speed with this fault? I'm wondering if it is sensible to drive it to the garage. For the last few miles, when the ABS and PSM lights were on, low speed driving was stable - brakes were smoothly applied, car could pull away from halt.
VarioSpam (07-02-2022)
So likely to be the Battery or ABS sensors.
My experience here: https://rennlist.com/forums/cayenne-...l#post17740075
The short version I changed the battery but faults displayed were down to the faulty ABS sensor. Having said that at 10 years old the old battery was definitely passed its best.
Oh, BTW, were you able to continue to drive it at all like this, or did it keep failing to pull away?
