Intake pipe flaps and auxiliary coolant pump faults 2011 Cayenne S Hybrid
Engine V6 3.0 Hybrid, 246kw.
Getting these fault codes:
P192B00 -Auxiliary Coolant Pump in HT Circuit, Mechanical Fault
P055600 - Pressure Sender For Brake Booster - Implausible Signal
P042000 - Bank 1 Catalytic Converter System
P043000 - Bank 2 Catalytic Converter System
P202000 - Intake Pipe Flap Position Sensor 2/air Flow Control
P200700 - Intake Pipe Flap For Bank 2 Air Flow Control Closed
P200600 - Intake Pipe Flap For Bank 1 Air Flow Control Closed
P049200 - Bank 2 Secondary-air System Malfunction
P049100 - Bank 1 Secondary-air System, Flow Below Limit
Anybody knows where should I look for problems? Could it be stucked flaps in the intake manifold?
Auxiliary coolant pump location? Is it in front of engine at the bottom?
lml999 (04-20-2022)
