Porsche 958 Cayenne Turbo jerky with hot oil
Hi All,
I'm new to the forum so excuse me if I post this in the wrong topic.
I have a Cayenne Turbo 2011 for 2 years now and drive it with full satisfaction. There is 130.000 KM (80.778 miles) on the odometer. Since a half year or so I feel a jerky motion when the oil has reached it's maximum temp. around 95 degrees but it is only in 2nd and 3th gear under accelaration. When the oil is lower then 95 degrees there is no problem at all.
I already changed the plugs and used a bottle of forte advanced system cleaner. I've read about the transit case but there is no jerky feeling or stuttering at all when I make a tight left turn. Also it is not really stuttering but more like it has something to do with the drive train. However, I don't think that is the problem because it is only when the oil is hot.
I'm planning to do walnut blasting and transmission cleaning but in my opinion it is more a mechanical 'thing'.
Any ideas or suggestions? Thanks in advance.
lml999 (03-02-2022)
Those are the same symptoms of my faulty transfer case, that is being replaced next week. Porsche extended the warranty to 10 years from the date of manufacture but, that would put your 2011 out of warranty now.
