2013 Porsche Cayenne Diesel injector replacement
Hi everyone.
I need to replace some injectors on my Cayenne Diesel.
Any suggestions for part number.
I got quote from Porsche dealer and it is so expensive. Like $1200 each.
Thank you in advance.
I have the same exact vehicle, so following this thread... How did you come to the conclusion that you needed to replace injectors?
Can they be done individually, like replacing a single faulty one, or do they recommend replacing them all at the same time?
I've seen some areas for coding the injectors in my Launch tablet, so I guess I have one of the necessary tools if/when I have to take this plunge...
Keep us posted, as I don't see anything about this in the how-to area.
Not sure if this is the correct one, but maybe a start:
https://www.europaparts.com/fuel-inj...9130277em.html
EDIT:
Porsche Factory part No (old): 95811012820
Porsche Factory part No (new): 95811012821
The part linked above shows an equivalency to the old Porsche part number. The new part number could mean lots of things, like a different manufacturer, or a different material somewhere, and doesn't necessarily mean a functional change.
EDIT2: BOSCH 0445-117-032 appears to be the generic part.
EDIT:
dollarlongnecks (01-25-2022)
If you are able to have the down time, remove them, send them to an injector cleaner and have them calibrated...much cheaper than new...if you can wait.
Hi,
I replaced two of my injectors a few months ago as i was getting lumpy running with ticking and hissing from the engine bay which is indicative of the injector seals.
I bought Bosch Injectors which were £210 each ($285)
If you do this yourself you will need new seals, copper washers and stretch bolts (single use)
Pretty straight forward although some of the fuel line bolts can be awkward to access. Car is now running like a dream.
I also bought a few other bits to help with the job -
6X New Injector Seal Rings Bolts Audi VW 3.0 TDI 059130519B WHT004923B WHT000884 | eBay
Amazon.com: 10pcs Seat Cutter Diesel Injector Set with Flat Reamer T-handle Angled Reamer Hex Key Fit for Mercedes-Benz PSA Renault Bosch : Automotive
Amazon.com: NEIKO 00325A Wire Brush Attachment for Drill Set | 38 Piece | 1/4" Hex Shank | SAE/MM | Stainless Steel, Brass, Nylon | Mount on Power Drill or Die Grinder : Industrial & Scientific
Amazon.com: ABN Diesel Injector Puller Tool with Slide Hammer, Common Rail Injector Remover w/ M8, M12, M14 Thread Adapter : Automotive
The following 3 users liked this post by mikegally:
We have replaced 5 or 6 faulty injectors and glowplugs on our Q7 TDI under the dieselgate warranty. Dealership refused to replace any besides the one currently causing the fault, which was "Cylinder x contribution/balance" each time. A mechanic buddy with a TDI Touareg swears by a diesel additive that apparently prevents this from happening. I will definitely start to use that once the warranty is up (about 9 months left) but in the meantime happy to have it covered by the warranty. Price out of pocket I think would have been around 1700 each time
I think I've probably put a bottle of some sort of additive in nearly every tank since I got the vehicle. I've always heard US diesel isn't up to par with the standard in Europe, so I figured I'd play it safe.
I'm currently using Stanadyne products:
dollarlongnecks (01-27-2022)
