Sponsored By:
Sponsored By:
RPM related ticking sound behind Tachometer
Old 01-13-2022, 11:06 PM
incorigeable
incorigeable's Avatar
Default RPM related ticking sound behind Tachometer
Throwing this out there to see if anyone has faced this issue. There is a slightly annoying ticking sound that seems to emanate from behind the driver console - perhaps the tachometer - that appears between 2500 and 3500 RPM. Disappears above 3500. To me it almost sounds like a fan blade slightly out of alignment brushing against its housing. Only on acceleration. It's not really a huge deal but definitely noticeable. Wondering if maybe its a harmonic type issue. 2016 Turbo S. Thoughts?
Old 01-14-2022, 02:05 PM
SnowShoeBar
SnowShoeBar's Avatar
I think what you are hearing is the vacuum pump. It’s noisy.
Old 01-17-2022, 08:56 AM
Nhirsch
Nhirsch's Avatar
Maybe bushings broke that were holding power steering line up. It dropped down and taps against the chassis. Happened to me
Quick Reply: RPM related ticking sound behind Tachometer
