PCM Bluetooth Enabled for Calls Music
Former Vendor
PCM3.1 OEM factory Bluetooth enables as per VIN.
What you need to prepare:
piwis3 PCM => Maintenance => functions enable with the code we supplied => coding
- Porsche PIWIS2 / PIWIS3 with engineering system
- Bluetooth enabling code
- Microphone for calls, For installing the microphone you have to dismantle the PCM Head Unit and install the microphone at the top of the driver side.
