[CD] Installed the Dipstick
So after reading a bunch on some old threads i went ahead and installed a dip-stick (VW p/n 077-115-607-K) into my new to me CD and my initial impressions are pretty negative.
Cons:
TIA!
Cons:
- The dip stick is quite difficult to insert. It's strange but it seems to have a proper orientation in order for it to go in smoothly. I'm not only talking about the metal being oriented West to East but it almost make a difference as to which side is facing South. in my case there's a little indent on the orange plastic piece that since inside the tube. If that piece is facing South then the dipstick goes in much easier than if it's facing North.
- The dipstick itself is pretty useless. Any time I pull it out it's covered in oil probably a good 8 inches up from the top little plastic piece (max level). My electronic gauge shows the correct level though.
- I need to find a place to put the dip stick tube plug where I won't lose it.
- I have a dipstick.
- I actually didn't have to cut the top off of it to make the engine cover fit. I just needed to reach under the engine cover and push the handle back towards the cabin a little bit and the engine covered popped back on very easily. Didn't have to force it at all.
TIA!
Yup, of course.
Wipe clean, re-insert, pull out, check where the oil is at and it's a long ways past max. It's obviously getting residue on it somehow,
Would anyone mind confirming the length of their dipstick for me? Maybe the parts guy screwed up and gave me some mega long one that bends into the bottom of the oil-pan.
Yup, of course.
I'll measure the dipstick on my Q7 TDi and post...
Cons:
TIA!
Cons:
TIA!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I knew any further attempts would be futile. Prolly break some pieces inside the oil reservoir. I now use the dashboard electronic gizmo. Works fine.
I don't remember whether I added the dipstick or the Q7 came to us with it (bought used).
Some googling found this Audi part number -- 059115611AB. Not positive its correct....
So mystery solved. My dipstick is 26.5" long. Explains why it jams and is covered in oil. Either the parts guy gave me the wrong one or i messed up the part number.
@lml999 Any chance you have your part number handy?
Said extracter hose got caught on the baffles in the oil pan and no amount of swearing, cajoling, pleading, praying, etc., got it unstuck. So pulling and more praying commenced. Extracter tube elongated and finally broke off, leading some six+ inches in the pan.
Engine started up normally and didn't implode. Daughter drove back to her home 200 miles away.
A week later local mechanic dropped the pan to replace it, as it was rusting through. When he found that snake in the bottom of the pan, um, he was a bit surprised, to say the least. Couldn't figure out whether the Q5 had a tapeworm or something had let go in the engine and made its way down to the pan.
Not long after that I, I mean this guy, called the mechanic and asked if he had found anything unusual in the pan.
Laughs ensued.
Just saying.
Originally Posted by Dr. G7
Martin, please may I ask what’s the “keenest” with the dipstick? IMHO it’s not worth the effort. Especially if you break off something in the dipstick tube. The instrument cluster oil indicator works; once you get the hang of it. It’s not as “convenient” as the dipstick…but I can check the oil level while doing 70 mph too.
There was a guy, not naming names here, who used an oil extracter on his daughter's 3.2 Q5 and inserted the extracter hose too far down into the engine.
Laughs ensued.
Just saying.
Laughs ensued.
Just saying.
Exactly. This scenario of something breaking off and falling in the oil pan is what I imagined when trying to wriggle the dipstick.
luckily the Audi oil pump didn’t pulverize the snake and distribute throughout the engine. = new engine!
For me it's the convenience factor. I want to be able to change the oil and get the right amount in there without having to get the electronic sensor to register the reading. And I also do prefer a physical measurement to an electronic one. Call me old-fashioned but a dip-stick has never let me down while electronic sensors well, that's a different story.
Also don’t forget, Porsche prolly shaved fifty cents per car by omitting the dipstick. Someone has to pay those nine figure bonuses to the Porsche executive committee. Especially after some of them endured vacations courtesy of the German government, i.e., jailed for the dieselgate
