Hi everyone, haven't posted here in quite a while, life's been crazy and just finished up what was probably the busiest summer of my life this year.
Anyway, my 958.1 Turbo S has been leaking oil. I know the leak is extremely slow because I topped off the oil in June I believe, (5 months ago or so) and my oil level still shows to be right in the middle of the "Min" and "Max indicators. Not to mention that anytime I park, it appears to drop just 1 or 2 drops of oil, it's never a puddle.
I have an independent mechanic that is a very close friend (I fully trust him), who took a look at it and seems to believe that its the rear main seal. They checked the valve cover gaskets which appear to be clean, and they said it's definitely coming from the back of the motor. Has anyone dealt with something similar? The car has a decent amount of miles on it so I was fully aware I might run into some issues like this. Rear main seal appears to be a motor out process, and if that is the case I will be doing a complete overhaul and reseal of the motor, and catless primary downpipes, (possibly even Pure850 Turbos) so there is somewhat of a silver lining.
Did either of you replace your vacuum pump at the time? I just replaced the coolant sensor that screws into the head and had to remove it to access the sensor. The vacuum pump seems to be working fine (I’m at 95k on my 13 GTS) so my plan is to just replace the 2 o-rings.
Is it near the oil cooler area? I think I have a leak as well, seems to be covering that area pretty well - it’s kinda near the oil drain
is there a diy on the vacuum pump?
For those where the vacuum pump was leaking, did you get a burning smell?
I get a slight oil burning smell from the back of the engine, but weirdly enough I haven't gotten one drop of oil on the ground. Wherever it's leaking, it must be dropping onto the exhaust and burning off, hence the oil burning smell.
Initially I thought it might be the HPFP but since several of you have said it's the vacuum pump, I'm starting to suspect it.
Yup, the belly pan was pretty clean when I took it off, which was surprising. It's the weirdest oil leak I've ever dealt with, because I can definitely smell it in the rear engine area, but it completely burns off on the exhaust manifold without anything dripping down.
