Changing engine mounts - 2011 v6
That's interesting, what year is your VR6? I have that noticeable brief vibration when coming to a stop on our new CPO 2016 VR6 and I also noticed a wahh wahh sound that went away when plugging the PCV valve hole, the dealer agreed with me and are replacing the PCV/valve cover - hope to finally get it back on Mon. If the vibrations aren't gone I'll pursue the engine mounts. 2009 VR6 seems good now but I'll be replacing the suspension on it later this month.
Mark
[QUOTE=v0dka;18571093]Yes absolutely. In my case, I had a vacuum leak AND shot mounts!
Engine mount symptoms were a harsh vibration felt through the chassis of the vehicle, noticeably worse when putting the shifter into reverse. Also when slowing down to a stop, there was a short, strong vibration felt just before bringing the vehicle to a stop. This has all cleared up with the new mounts.
I also had a hole in the plastic breather hose on the passenger side of the engine that revealed itself when it started dripping oil onto the exhaust. I temporarily repaired this hose and ordered a new one from the dealer (approx $70, quite reasonable). My Cayenne is around 77k miles.[/QUOTE]
Mark
Mark
Mark
