Sponsored By:
Sponsored By:
Auxiliary Coolant Pump Access
Old Aug 20, 2020 | 02:13 AM
PK911's Avatar
PK911
Default Auxiliary Coolant Pump Access
My Cayenne base V6 is throwing a P261C00 code (coolant pump 2 short circuit to ground). This past weekend have been trying to take a closer look at what is going on with the auxiliary coolant pump but could not access it. Based on my research it is sitting being the engine (cabin side), above the transmission. I tried accessing it from under the car, above the car, removed the passenger side fender liner but none of these options worked.
And unfortunately ALLDATAdiy does not provide instructions on how to replace it. Any ideas how I can get proper access to it without removing too many parts?
Thanks.
Old Aug 20, 2020 | 11:43 AM
dbv1's Avatar
dbv1
Should be the same on 955/957. Any luck searching?
Old Aug 20, 2020 | 01:22 PM
PK911's Avatar
PK911
No luck searching. Looked at Google, Rennlist, Renntech, Pelican Parts but no luck. Obviously, lots of articles regarding the water pump but nothing regarding the auxiliary coolant pump...
Old Aug 22, 2020 | 12:22 PM
dbv1's Avatar
dbv1
Check the relevant fuses too, probably not a bad idea.
Not sure how to get to the pump, looks to be right under the cover. If you figure it out, please post here.
Old Aug 22, 2020 | 01:32 PM
PK911's Avatar
PK911
I checked the fuses. The one for the pump keeps blowing out....
I’ll give it another try this weekend. If I can’t get to the pump, I’ll just send the car to my shop.
Old Aug 22, 2020 | 06:01 PM
RAudi Driver's Avatar
RAudi Driver
Are we speaking of the second water pump that is used to heat the car's cabin? That's located under the wheel well on the driver's side of the car, not the passenger's side.
I just got done with both wheel wells and should have taken better pictures of the driver's side while the cover was off. Here is what the driver's side looks like and I think the pump is accessible vis this route.
Old Aug 22, 2020 | 07:40 PM
PK911's Avatar
PK911
Thanks, RAudi. I’ll give it a try from the driver‘s side and will post the results.
We are talking about the same pump.
Old Nov 26, 2021 | 10:58 AM
72911's Avatar
72911
Where is the pump located in the wheel well?
Old Nov 27, 2022 | 01:46 PM
Danisl87NY's Avatar
Danisl87NY
2nd Gear
Any photo to help to found it please?
Old Nov 27, 2022 | 02:03 PM
CAVU's Avatar
CAVU
Search is your friend.
https://rennlist.com/forums/cayenne-...rol-valve.html
Old Jan 3, 2023 | 07:09 AM
Danisl87NY's Avatar
Danisl87NY
2nd Gear
Originally Posted by CAVU
but we are talking about aux pump, and they are talking about heater control valve…
I’m confused 😐,
Old Jan 5, 2024 | 09:55 AM
audiomutt's Avatar
audiomutt
Doing a quick share here since this is the first post that comes up in a google search.
Confirming a few things:
- Alldata has P&L info, but does NOT have replacement info.
- This is located behind the engine block favoring the passenger side, not the driver side fender (on a base 3.6 at least)
Here is a pic of the drvier side wheel well. There is a water valve located there, not aux pump (this is a 2012).
Here is the general location behind the block
And here is an up close shot of the pump wrapped in the heat cover
@72911 mentions here spraying some wd40 on the connector and making sure it had a tight connection fixed their problem:
https://rennlist.com/forums/cayenne-...l#post17848290
Old Jan 20, 2024 | 10:49 PM
audiomutt's Avatar
audiomutt
Finally got around to looking at this today.
Similar to 72911 i had a tough time getting the connector removed. I ended up taking a 90° hose pick and slipping it under the tab from the rear. Connector came off pretty easily after that. I had a bit of noticeable something or other.... corrosion/rust I guess. Cleaned it up and reattached. Doing some other work on the car so I can start it yet, but I'll report back if that solved my issue.
Old Feb 17, 2024 | 02:59 PM
audiomutt's Avatar
audiomutt
Quick update on this.
After cleaning and reattaching the plug, my CEL turned off. It stayed off for about 40-60 miles or so, but today it turned back on with the same code.
Old Aug 1, 2024 | 04:27 AM
wrscott's Avatar
wrscott
Did you ever resolve this issue? I'm getting the below codes on my 2011 Base 3.6 Cayenne
P261A - Coolant pump 2 circuit open
P261C - Coolant pump 2 circuit short to ground
Going to see if I can run the pump manually using my Autel, if not will try cleaning the connectors and replace if the issue remains.
Anybody have a part number for this auxiliary water pump that sits behind the engine? Crazy that this little pump throws a check engine light!
