Windshield defrost acting up
Hello all ,
This might be not relevant but yesterday i cleaned my windshield from inside because i noticed there are some spot marks that came visible when i am facing sunlight. when i started up my car in the morning i noticed that the front windshield started for a second then went off, then it started back up again for few seconds and went off again. I started to drive with cold weather in the morning and my windshield stated to fog, i turned my front windshield defrost on hoping it can clear out the fogging, it kept running for a good 30 min and the fog didn't go away. I stopped and turned the car off off. the air did not stop, even with the car is shut off. after few minutes, the air went off. did that few times and it stayed the same, air running after the key fob is out and the door is open.
I was looking around and i saw that it could be some fuses. there there something else i need to look for ?
Thank you all.
Thank you all.
