Trickle Charge
That outlet (and the one in the passenger's footwell) shuts off after a period of time when the key is off. I'm not sure about the outlet in the hatch area, but it probably is similar.
@Quadcammer You're saying if it's charging, that port stays active even when the key is off for 30+ minutes? Interesting!
I hooked the pigtails matching colors in the engine bay for jumping the car. Red to nut to be unscrewed under a red plastic cover with a big + sign. Ground/black stem is just a weird shape nut which you can unscrew with a socket.
Not following what the challenge is here.
RED HORSE (05-01-2020)
I've had no issues with it.
Eskimo1 (05-05-2020)
My Deltran Battery Tender charged up my Cayenne's battery just fine using the Cig lighter in the center console. 958.2
I charge the 997 and 991 the same way.
Originally Posted by XS29L9B
Thanks. I see where to place the red lead, but cannot see the post for the black, or ground. Pics?? Thanks!
Originally Posted by JamesN
which Ctek tender is good for a 2016 diesel?
thanks
Jim
thanks
Jim
CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V (40-206)
That's how I have to use my trickle charger, connect them to the terminals under the hood which is a pain I have to open the hood. I used to utilize the cigarette lighter in the center console but it would get shut off after 15 minutes or so after the ignition is turned off. The weird thing was it didn't use to turn off but maybe the dealer changed the programming or something after a service and it stopped working. I have 2011 958.1.
