2013 Porsche Cayenne Hybrid whining noise. Transmission?
I have a 2013 Cayenne with the 8 speed tiptronic transmission. Shifting seems fine but while driving there is a very annoying whining noise. Does not happen in idle only while driving. At speed, when I put the car into neutral, the noise stops completely. I have been reading that it could possibly be low transmission fluid. My car only has 78k miles on it and the recommended fluid change is at 160k. Any ideas on what could be causing this noise?
Low transmission fluid would make the shifting on your car irregular.
Can you post up a video?
There is some rain noise but you can hear the odd noise pretty clear. Towards the end of the video I put the car in neutral and the sounds goes away.
