What do y’all clean you rotor hats with?
I use both the Porsche wheel cleaner and Meguire's Hot Rims sprays, sprayed on to a cool wheel for a minute and then lightly scrubbed with a wheel brush. Both products seem to do the trick in my case (calipers and of course the rims too). The Porsche product is a bit thicker, so it adheres to vertical surfaces a bit better. Both seem equally effective at cleaning though.
Keep in mind my rotor hats are in good shape, so this process maintains them and keeps them clean. If your rotor hats are especially dirty or have other issues, you may need to take a bit more aggressive approach however.
If those are OEM rotors isn't the hat a polished finish?
Mine are super easy to clean with a woolie stick and regular car soap.
