Ambient Temp Sensor Location? Passenger Side
Hi all, while installing the CarPlay retrofit into my 2013 CD, I knocked off the Ambient Temp Sensor. I have no idea where it is supposed to go. Any help would be great. Also, how much do I need to remove to get it to go back in?
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1250/screen_shot_2020_01_12_at_8_44_09_am_54a3d767eab71ef0f2155b25a1997511bb7b9bce.png)
5, Center Left ATS
6. Center right ATS
7 Pollen filter ATS
3 and 4 are the lower vent ATS's
1 & 2 are the outer ATS's but I don't think these are the ones that would have fallen out if you messed with the PCM.
Thanks. Are 6 & 7 also the same sensor? It is possible it could be one of them too (I was running wires to below the glovebox).
I think 4 falle out if you ran wires under the glove.
Don't know if the filter and the vent sensors are identical. You'll just have to get under and start looking for a spot that's missing a sensor.
