Trailer hitch prep option ?
Hello
I am a member of the 996 Forum.
I am looking to purchase a used Cayenne
I need one with a trailer hitch.
I know without one, it is close to $2000.00 for hitch, ecu reprogram etc, to get one completely installed.
However, I am finding a few trucks with trailer hitch prep package, but no hitch.
What does this mean, consist of?
How much is involved in completing the truck with a hitch?
Thank you
David
Apalachin, NY
Thank you
David
Apalachin, NY
Yes, this is easy to do and breaks down into 2 focus areas :
Conclusion : this is feasible in an afternoon's work and will cost you about 500$. Hitch can be aftermarket, control module + wiring should be OEM.
Hope this helps.
- The physical hitch/bar. Installing this will be a 1 to 2 hour deal since you need to take off your rear bumper. Just look on YouTube to find instruction videos. I went with a 110$ Curtis hitch from what I recall, not the spendy Porsche one. Works like a charm.
- Control unit + wiring. I just called Sunset Porsche in OR and had Luke assemble me a list of all the components I needed. Everything arrived within a week. The control unit is shared by VW/Audi/Porsche and goes behind your Bose rear amp (cargo area). Pulling the wiring all the way to the hitch was not that bad, let's say that this was another 1 to 2 hour task. Total cost for all these OEM components was about 300$ from what I recall (Sunset only takes a 5% mark-up)
Hope this helps.
Hope this helps.
Hope this helps.
The electrical is the part I was questioning.
If the vehicle has tow prep option, but no hitch, is the wire already there and the control module already programmed.
Is there a larger alternator and additional cooling units with tow package.?
I cannot locate any documentation on the exact description of the Trailer Tow option and the Trailer prep option.
What do you mean trailer prep option? When I was looking the build sheets would say “1D6 Trailer hitch without tow ball”. This is the whole thing: hitch receiver, wiring & module. All you need then is whatever size tow ball for your trailer.
What do these mean, when there is not a receiver mounted under the truck?
1D0 Without towball
1D1 Trailer hitch, removable, lockable, ECE R55
1D2 Detachable trailer coupling
1D3 Trailer hitch, electrically retractable, ECE R55
1D6 Trailer coupling without tow ball
1D7 Preparation for detachable trailer coupling
1D8 Preparation for detachable trailer coupling (American version)
1D9 Electric folding trailer coupling
1D0 Without towball
You're overcomplicating it
The connectors for the hitch control module seem to be part of EVERY wiring harness. My car did not have the trailer hitch option, however, I found the required (unused) connectors behind the Bose amp in the back.
All you need to do is plug in the control module and run the wiring toward the hitch from there.
In order for the ECU to recognize the control module being present you need to activate it through PIWIS. That's all. Any Cayenne should be able to accommodate for this, even if it did not come with the OEM trailer package.
Since we're on the topic of installing hitches and modules, I want to confirm the Cayenne doesn't need a trailer brake controller like you would install in a 1995 F-150, correct? The module provides power to the electric brakes and some logic in the Cayenne interprets pedal pressure, pitch, etc. to send the appropriate power to the trailer brakes?
I'm buying my first Cayenne tomorrow and have been reading a lot but don't want to make ASSumptions. I'll make a proper introduction thread with a bio and some pictures tomorrow night. Awesome board here - thanks!!!!
mr_hyde (01-06-2020)
1D0 Without towball
1D0 Without towball
If you're shopping and see a cayenne for sale, go to vinanalytics and put the VIN in there. it will give you the porsche build sheet and if you see 1D6, you know that's a factory installed hitch with everything but the ball. And yes, mine does.
