Cargo Management System install / mod - Cayenne 958
Picked up parts to install the OEM Porsche Cargo Management System & installed it in my Cayenne 958 last week.
I am pretty happy with the results & thought I would share.
parts
958551556019Q8 = qty (1) retaining strip right
958551555019Q8 = qty (1) retaining strip left
N90850202 = qty (4) M8 x 20mm retaining bolts (triple-square screw)
95555150400 = bag loadspace system - four cargo anchors, one retractable divider, and a durable, fitted carrying bag. (you will just store this with all your other parts, its not really useful for anything)
tools used
Torx 25 - to remove the original cargo
flathead driver - (thin) to remove the original rail (middle clips)
Torx 50 - to install the 4 new bolts
considering adding these parts
* 958-551-769-00-DC5 = Mat - Porsche
* 95504400203 = rear Luggage Net Set (floor & one side net)
---- I believe the VW version (p/n 1KM065110A) is only the floor net (missing the side net) & the hooks are only one side + the P tax)
thoughts
* really on the fence on buying / using the OEM mat (958-551-769-00-DC5), anywhere I look its over $200+
* the bar is really useful for grocery bags or just gym bags in general
* have not used the retracting strap yet but believe it might be nice for small / medium size boxes
* I picked up the VW net for $15, paying $85+ for the Porsche OEM net / side net does not seem to really add value (unless I am missing something?)
please forgive my dirty bumper, I have some hard water & still need to install a filter system for my garage hose
finish w/ cargo management system installed
with system
laying out the parts
right rail removed, four screws per side with a TORX Driver Bit - T25. Be careful, there is a middle tab still holding on the original part
right rail installed with a TORX drive bit T50
system installed. thats the fancy bag part of the system came in
#14 & 15 are some of the parts
OEM floor mat you use with cargo management system
parts
tools used
thoughts
with system
I put grocery bags behind the bar and lock it into place & put boxes in the wrap system vs everything just sliding around.
hope these pictures / p/n's help someone else.
I am all in for modding / adding on things to my Cayenne & always moving around boxes & such.
clearly not for everyone but the used parts price was right & I like it / have use for it, which is all that matters.
coffeeisgood (11-08-2019)
How much is this system. I have a homamade system that works fine for me but if this is cheap.......
Cheap and Porsche those don't match that actually made me laugh haha just kidding you can save a few bucks with the crossbar I'll sell it to you cheap just want it out of my garage
Question. Does the 95555150400 = bag loadspace system include both the retractable fabric AND the metal bar? Looking at the part number and description, it says it does but I can’t tell if it does or not? I already have the rails for the CMS but none of the additional stuff to utilize the system. I purchased mine pre owned so the previous owner may have taken the parts out. Thx!
i think this option was $600 USD? as an option if purchased with a new Cayenne
if my memory was correct, i picked up the system used for $280 USD (which I think was a pretty good deal)
& saved on shipping by driving a hour (2 hours round trip) to pick it up. It was my first good drive in my new to me CD, so I did not mind.
i used the strap system the other day to secure a 30 pack in the cargo area. the two pillar strap system can fit in the wheel well if you like it out the way but i just leave it attached on the side
the biggest issue i face right now is I need a smaller brush attachment for my vacuum system to just get quickly / easily into the cargo rail areas. (I live next to the beach, so sand happens). I am sure its it will be like a $15-$20 vacuum attachment....
Someone recently had this whole set on eBay for less than $300, and I posted it here so someone had a chance to grab it... When I did this install, I has to source all the used parts separately, and it took some time, but definitely worth it.
I ended up buying that one. It s under 300 but that price was in British Pounds. With exchange rate and shipping I ended up paying something like $360 or so. Not bad at all considering new options usually run between 700 and 800 from what I've seen
dollarlongnecks (02-02-2020)
Very nice. I had considered that system for my 958, but in the end I just purchased the OEM reversible cargo mat which retains access to the floor anchors, and the OEM cargo net. Kept everything in place perfectly for the stuff I typically carry (groceries, etc.).
I could see where the cargo mgmt sys would probably work better for securing larger cargo though.
