958.2 Jack point?
I've seen 958.1 jack points but wanted to double check if anyone know best place for jack points for 958.2 front/rear.
For instance, put a car jack somewhere front middle point and once car is up, then I can put two jack stands by wheel - which is indicated on manual but I'm looking for the initial jack point for front and rear.
Yeah, I think that's the jacking point manual is indicating, which is where I'll be putting jack stand once car is jacked up - but I'm looking for alternate jacking points so I can put jack-stands into area you are indicating.
Just look under it and look for a frame point that is suitable. If you don't see a point you feel comfortable using, then jack up one side at a time, place the jack stand and do the other side.
I think is this should help, even if it's for the 955:
https://www.pelicanparts.com/techart...ur_Cayenne.htm
