GTS launch control
So i have a 2016 GTS with sport chrono package(sport plus). I heard that i should have launch control. So yesterday, i went on a empty road. To a full dead stop, put the car in Sport + Then, hold on the brakes thight, floored the throttle. Launch control didnt engaged, at least i didnt see anything in the cluster that said so, like the video i watch. Am i doing something wrong? Or maybe i dont have for some reasons??
2016 GTS with SC also and yes you have launch control.
I put suspension in sport+ also but not sure if that is necessary.
Brake has to be mashed to the floor.
Throttle mashed to the floor. It will say "performance start activated" in the instrument cluster.
throttle will hold around 3k RPM
release brake and hold on.
Since we all have the same 8-speed conventional auto transmission - What is this doing that the standard car won't do without the SportChrono package? With the dual-clutch like in a Macan it makes sense what's going on (clutches are disengaged, maybe even a little timing retard to help spool the turbo), but with a torque converter in play, I'm really curious what's going on behind the scenes?
It shaves off a couple tenths so its doing something! Beyond having the sport plus button which changes engine and transmission response, I think launch control calculates the most efficient starting rpm and most efficient shift points disregarding everything but the fastest time possible. I don't think the other driving modes do that. I read a specific example is launch control eliminates any chance of wheel spin whereas just flooring it will not.
I guess if you could find the most efficient starting point and manually shift as perfectly as the computer you could duplicate it? Still maybe not then unless you also had the Sport+ driving mode...
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
wkearney99 (06-24-2019)
The manual explains it:
http://porscheownersmanuals.com/2017...9/Transmission
