Terrible roads, what to do?
So I just moved to Louisiana for a great job opportunity. I didn’t know how bad the roads are over here. They are so bad it’s alarming. Everywhere I go it’s THUMP -thump, THUMP - thump, THUMP - thump.....
My Cayenne S doesn’t have air suspension and my tires are currently set at full load pressures.
Will adjusting the tire pressure down to partial load help much? What about trading Cayenne in for one with air suspension? Or, am I just SOL? We’ve been renting suvs for moving purposes and noticed the Buick Enclave was much smoother on these roads. Not going to be getting a Buick though!
I can’t wait to get my Boxster over here and really trash it. :-(
Help?
-Matt
Help?
-Matt
Help?
-Matt
Help?
-Matt
buy some 19in wheels and do 255 55 19 tires?
lowering the pressure should help.
what size tires are you running? I live near a construction side and trust me, that road I take some times is the worst in this country that is paved. Probably worse than some of the petrified roads too. I have 21s and air suspension and it still hurts in comfort chassis.
Ive got 20in RS Spyder wheels right now. Would probably be better to put the money toward a Cayenne with air suspension:-)
I’ll definitely try lowering pressure. Hopefully that makes enough difference for me as trading in for a Cayenne with air suspension won’t be cheap :-(
How much difference does comfort feel vs sport? I imagine my non air Cayenne is basically like sport for you?
-Matt
-Matt
Your non air is probably in between comfort and normal. Sport for me is quite harsh.
And with my GTS, it may be that my comfort is your standard suspension and comfort in say a turbo or S equipped with air is even more comfortable.
There's absolutely no reason to run your tires at the max load listed. Lower it to around 32F 36R and you should see improvement. Also softer tires with more sidewall will be a good option in your case.
A smaller diameter rim as well as a meatier tire will help in this case. If you can't get rid of your 20's then look into a higher profile tire.
I'd be against lowering tire pressures too much as you're going to induce more sidewall flex. If you hit a pothole just right you're looking at a bent rim.
Id air suspension isn’t that much of an improvement, I may just have to learn to live with it. Man it’s annoying! I’m guessing my suspension will need more maintenance than usual?
I drove through Louisiana years ago and I was appalled by the condition of the roads. I live in Georgia and have a 2017 GTS with air suspension and 21" wheels. I run the partial load air pressure of 35F and 38R. the ride is much rougher than my 2015 Macan Turbo with 20" wheels. The Macan also had air suspension. I'm seriously considering 20" wheels.
Originally Posted by Mrg02D
.... Any good all seasons that may help with the clackity clack?
Thanks, I’ll give them a look. I prefer to stick with the 20in as I really don’t want to put any money into this car. I may trade it in for a Cayenne with some more options (like air suspension) after the CPO warranty is up.
