Sponsored By:
Sponsored By:
2014 CD TPMS Problem
Old May 14, 2019 | 09:21 PM
schwarz633's Avatar
schwarz633
Default 2014 CD TPMS Problem
I recently removed all 4 wheels, cleaned them, removed the weights, and took them to a local independent tire shop for new Pirellis. After the new tires were mounted and balanced I randomly installed the wheels back on the CD. I didn't keep track of the original locations as I had rotated the tires a while back and the TPMS automatically relearned after a short drive. This time however it hasn't relearned 3 days later and my wife has been driving it every day. On start-up I'm getting a "Tire Change?" message and none of the tire pressures are displayed. The TPMS icon is also displayed. Is there something I need to do on the dashboard display to trigger the relearn process? The tire shop is well established and highly regarded, so I'd like to think that they didn't damage a sensor(s). As I understand it, they don't even touch the sensors, just work around them. I'm going to reach out to them as well to see if they have a TPMS tool that can read the status of each sensor.
Old May 15, 2019 | 09:10 PM
schwarz633's Avatar
schwarz633
As it turns out, you need to select the tire size and type (even though unchanged) to trigger the learning process. I did this stopped in the driveway and after driving about 2 blocks all four pressures showed up correctly. I have to give props to the service advisor at Porsche Waukesha for providing me with that information, it wasn't obvious reading the manual.
Old May 16, 2019 | 09:03 PM
pdxmotorhead's Avatar
pdxmotorhead
FWIW,, if those are original sensors, your very very likely close to the end of the battery life (~5 years), so next time you take them off,, I'd buy batteries.
FWIW Discount tire stores often stock the rebuild kits.. And fairly cheap.
Old Nov 11, 2019 | 01:17 PM
avlis's Avatar
avlis
I've got this same problem. TPMS had been working fine. I simply rotated the tires to different positions and adjusted pressures using handheld gauge. Now I can't clear the "Tire Change?" message. I've tried the "Adjust" menu and selected arbitrary sizes and ran for a while. I do not get the "Learning" message...ever. Thoughts? Is there another menu other than "Adjust" that I'm unaware of?
Old Nov 14, 2019 | 05:04 PM
avlis's Avatar
avlis
I think I solved this. I dropped the air pressure on each tire down to 30 PSI and refilled to the door sticker pressures. When I restarted the car the display went into "relearning" mode then shortly after showed the pressures. Today I got the "Tire Change?" message again but didn't stop long enough to adjust the settings.
