Aftermarket Hitch Install + Factory wiring - Question
I decided to pick up a Draw-Tite hitch for my 2011 CS during the 20% eBay coupon sale the other day as the price was just too good. I likely won't need a controller right away but in looking at which controller would be needed it is, needless to say, a bit confusing as to which will work.
What I'm seeing is the current version is 7P0-907-383-G. It appears the the original version that came with the MY11 is 7P0-907-383-B and there seems to also be the 7P0-907-383-F for the VW/Audi variants. There are quite a few of the B/F versions available used. I know the G version will work but will either the B or F versions also work w/o any issues? I've looked around a bit but can't find any place that documents what the changes are between the various revisions.
Any luck with your install? I am going through the same process now (aftermarket hitch already installed w/o wiring). Which did you get (7P0-907-383-G)? Any links or install tips?
https://rennlist.com/forums/cayenne-...ing-hitch.html
