Confused about front rotor size 350mm or 360mm or 390mm
The Cayenne Turbo and Macan Turbo do not share the same caliper. You have what is the equivalent of a Cayenne base caliper, which is the came as the Macan turbo caliper.
The Cayenne turbo caliper has extended mounting bolt holes on the rear of the caliper.
You had 3 years to research this. What happened.![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I do have a confusion of my own. I have a base 3.6 cayenne with manual trans. 2013 model year. Nov 2012 build. US car.
18 inch wheels Black calipers.
called three dealers. Everybody quoting 360mm disks. While product documentation shows 350 and sometimes 360 in various marketing brochures.
Do black calipers accommodate both 350 and 360 disks?
if you look at pdf parts catalog - there is an option for "brakes for 18 inch wheels black calipers, North America. - which does cross reference to 360mm.
however there is also an option for black calipers for 350mm.
what's your build date?
what's your wheel size?
caliper color?
What I think is happening is that Porsche USA has standardized across 350/360 into 360mm size. I think black calipers support both rotors and there was no reason to stock two sizes so they just stated doing 360 for Base, Diesel and GTS. Just a theory. All dealers double confirmed that based on VIN it's the right part.
No, calipers are different part numbers, so they accomodate even larger rotors....however, because the knuckle is the same across all models - that means that bolt holes are the same - so if you get larger Turbo calipers, 390 mm disks, and probably hard brake lines - it should fit.
The following 2 users liked this post by schernov:
frederickcook87 (05-30-2023),
wkearney99 (07-08-2021)
thanks gents. I actually snagged a set of turbo calipers front and rear along with the dust shields for a really good price. My car came with 19’s, but I’m running 22’s. I’m hoping that everything will fit as long as I get the proper rotors and pads. I wanted a little more stopping power for when I tow with my diesel.
I know this because when I did the front brakes on my 2014 CTTS (390mm front rotors; steel (not PCCB)), I noticed that most parts sites listed two types of caliper bolts, which I've come to refer to as "short" and "long." I sent inquiries (with my VIN) to Suncoast, Pelican, and my local Porsche dealer and got conflicting answers--one said "long", another said "short" and perhaps the most honest reply was from my local dealer.... "we can't tell." LOL In the end, I ordered BOTH because I figured when I started the job, it would be a royal PITA to get it taken apart and realize I didn't have the right caliper bolt to get it back together. The bolts are about $5 each so not a huge expense; turns out I needed the "long" bolts.
There is a way to determine which bolt is currently on the vehicle. I'm going from memory here so can't confidently say I have this right, but the gist is that the different bolts have different head patterns. I believe the "long" bolt (which is on my vehicle) has a Torx socket and uses a T55 (I think) bit. The "short" bolt has a "triple square" socket and uses an M14 (I think) bit. Going from memory here so might have that reversed.
If you're changing rotors and calipers, this might not be much help because what's on your Cayenne now probably won't be what you need when going to the larger caliper but at least you'll be aware that there are two caliper bolt lengths and can research the subject yourself.
Good luck!
