Cayenne Side Marker Lights
Just recieved Euro clear side marker lights for my TT. There were no instructions how to install. does anyone have any insight or can lead me to the proper tech site for information? many thanks
quest,
Try this site: http://www.renntech.org/forums/index.php?showtopic=285
Also, if you will do a search here on Rennlist, I recall someone posted instructions with pictures.
Congrats - clear side markers definately look much better.
I recieved mine recently and just installed them using the renntech directions. I noticed that ESK (Eric) said that he left the white bulbs in - so did I. Does anyone know of the legalities of white side markers from state-to-state if there is one at all? What other bulb colors would be possible?
I purchased mine from Boardwalk Porsche here in Plano. Check your boxes before you leave to insure you have the right parts...... I wound up with a clear and a yellow and had to go back a second time. Installation is a snap.
Don't know if you can get them in the US, but over in the UK you can buy indicator bulbs that are white untill they flash, when they flash orange; keeps lens looking good, keeps you legal.
I would not call installation a snap...The passenger side is a real bitch to get the upper fastening torx screw screwed in, unless your left handed. Some people just bail out and screw in the readily accessible bottom one..It still holds the unit in place, but not solidly...Suncoast's site says that "professioaal Installation recommended". If you are not handy, I would recommend this. Installing them correctly fastened by both torx screws for each unit is NOT a snap, IMO...
http://e-partssales.com/Merchant2/me...ode=cayenneEXT
