Calibrating 955 Air Ride Height - Need SME Help
Old 10-16-2023 | 07:13 PM
  #31
MKITGO2's Avatar
MKITGO2
Default Where's it at?
Can someone advise where this CU is located?
I've been struggling with similar.. rear will not raise/lower properly, sometimes get an error.. other times it just seems to indicate height is 'reached' but no change. Lowering is the main problem. It will fill, but only bleed some of the time. Swapped out the valve solenoid block at the comperssor over the weekend.. no joy. Thinking the communication error with the CU makes sense.
Cheers,
MK
Old 06-07-2024 | 06:47 PM
  #32
Unibtanium's Avatar
Unibtanium
Cheers,
MK
MK did you figure out the locations of the leveling control unit? I need to swap mine it seems 06 ctts
Old 06-07-2024 | 08:54 PM
  #33
MKITGO2's Avatar
MKITGO2
i did. It is in right rear side compartment under the cd changer (if you have).
After swapping the module and no change, I took it to the shop. It was the check/bleed valves on the rear shocks for me that was the problem.
MK
Quick Reply: Calibrating 955 Air Ride Height - Need SME Help
