cayenne steering noise/squeak
Hi guys,
just got my first Porsche, a 957 turbo. Really like the car however I noticed a awkward steeringwheel noise today.
its exactly the same as in the vid below.
do you have any idea what is causing this noise?
thanks!
thanks!
The V8 Porschephile
This noise sounds like a failing coiled airbag spring behind the steering wheel. The spring houses the airbag wiring loom and resembles a typical coiled extension unit in your garage.
There's also a steering joint knuckle inside the dash which connects to the steering rod exiting the firewall. I've seen a lot of aftermarket wires wrapped around this joint causing shorts and similar noises.
Hi guys,
https://youtu.be/hywG_h4O51w
thanks!
thanks!
